Deadsfo
I am converting an ex Nato ambulance it is a 24 volts electrical system ,I can't make my mind up as to the the LB voltage, 24volt VB to a 24volt LB with a 12volt dropper or a 24volt VB to 12volt LB .The voltage has to end up 12volts because of the availability of fridges etc.
Is there any advantages to having a 24volt LB system ,the B toB charges are not that much difference in price .
My other point is what does a B to B charger give you that a much cheaper split relay charger does'nt.
I will have a 2 battery LB system.
