phils
Hi all.
I see most people recommend running their electronic items, where possible straight from the 12volt leisure batteries supply and avoid the inverter.
i understand this but how do you accommodate the different current rating of each item to charge when running from the one 12volt supply. For example my phone charger supplies a different output than my laptop charger or my speaker charger. If i was powering them using the inverted then the power pack of each charger would handle the step down from ac to the correct output, but how would this be done if running straight from the 12volt batteries?
This is all new to me :-(
