11kg or 13kg sized LPG locker door, used or new please.
Pudsey Bear
Fed up of silly 6kg cylinders, so need a bigger locker door, I thought perhaps someone may have one for sale.
Failing that the best dimensions to take those bottles please.
Why not do away with the door and install bottle from inside as i did, still you may find one somewhere.
Why not get a refillable LPG tank installed underside, if you have a spare wheel underside then they make doughnut shaped tanks to occupy that space and if in North of England then go see Andy Evans as he is one of the best Gas Fitters for MH's and LPG Engine change for vehicles I have ever met
Pudsey Bear
Too expensive really and not much room due to the water tanks being under the floor. I've been looking at used refillable cylinders but they all seem to be down south, I've found two so far but no one will deliver a used one, I did ask for a pony express deluvery but no joy.
I think a bigger door would help as well.
Pudsey Bear
At last got a 6kg red propane.
Miles away from the sea too.
