K9d
I have recently bought these seats on ebay leather captains seats maybe suitable 4 van conversions,campervans t4 merc etc | eBay, to replace the 26 year old ones in my Hmyer.
I will be keeping my existing swivel base to allow the seats to rotate, this is basically a turntable with a hole in each corner.
To make the seats fit I have taken the metal base off the bottom, it was that or amputate my legs to fit under the steering wheel, but I figured then operating the pedals would be tricky.
The holes on the turntables are 324mm apart, but unfortunately the holes in the seat rails don't line up.
My solution is 25mm box section, because of the mechanism to lock/unlock the turntable I can't just run a straight piece of metal along the front of the turntable but instead will need to use two mirrored pieces.
At the front I will drill an extra hole in the turntable on each side so there will be a box section held by two bolts that extends beyond the end of the turntable to meet the holes in the seat rail. The rear will have one long bar going all the way across and extending beyond the end again to meet the seat rail.
For the passenger seat I will need to drill a new hole in the seat rail to line up with the extended bar, on the drivers side I can just put an offset hole in for this.
Hopefully that makes sense.
So my question is should I use steel or aluminium ?, my preferred option would be aluminium as it will be easier to work with but I'm concerned that it may not be strong enough. It will have to support the weight of the seat plus my almost 15 stone and survive the forces that driving place upon it.
