Right ...
I am about to fit out my Galley Kitchen and need to get a pump to feed the tap. And also need the tap!
Don't Want: Submersible Pump and Microswitch fitted tap
Want: Tap with flexible outlet. I like this sort of idea ... Modern Monobloc Kitchen Mixer Tap With Pull out Hose Spray Single Lever Chrome | eBay
I only have a cold-water system so will probably connect cold and hot together with a Y-Peice.
Specs say minimum pressure 1 Bar so I think that makes it a Low Pressure tap and suitable to be fed from a container and pump?
Thoughts?
Pump that works on-demand when tap is turn on. I would prefer to have a setup where the pump turns itself on and off as required.
This kind of jobby I think would do the job ... FULLY AUTOMATIC DIAPHRAGM WATER PUMP 12 VOLT CAMPER MOTORHOME 100psi SELF BUILD | eBay
Thoughts on Pump? Suitable for the tap in the first link?
The Sink itself is probably going to be a SMEV 8006 Sink with Glass Lid as that is what I happen to have 'in stock' and is the right kind of size (need to blank out the tap hole as well, but that will be simple enough.
Might need to get a waste system (can't recall if I used the original one with the last SMEV hob/sink I fitted or if that came with one as well?)
Thoughts?
