Interesting. When I first looked at this setup I thought it wouldn't work with ECO mode (can't recall the reason now) but when I got round to trying it later it seemed fine.
What inverter size do you have? the inrush spike on the fridge is close to the surge limit of the 12/500 400W inverter. I wonder if the slight delay in the inverter going on from detecting demand is creating a larger spike that cannot be accomodated?
I have the Victron 12/500 same as yours I also have two inventer fridges the smaller 40L and the larger 93L I have only been testing the smaller fridge so far.
I may swap over to the larger one and see if it behaves, I may actually have a faulty compressor!
I would have thought bad compressor as well but that doesn't fully explain why all is ok on no-ECO mode (unless it is like I said about the spike is a symptom of a sticky compressor?
What you are describing is quite common with Air-Con Units I think and people fit Soft-start kits to make the starting a lot more gentle (I have one but couldn't see a way to fit it to the Fridge compressor)
Well I can confirm 100% that my smaller Inventor fridge does not like the Eco mode.
I left it running overnight on normal and it was fine but this morning as soon as I switched the inverter to eco it stalled almost constantly, this may well be a symptom of excess inrush current because I also get a high voltage alarm (again only on eco mode) so I think for this particular fridge the 12/500 is not up to it.
On the Victron site another owner seems to be having similar issues with a Liebherr TP 1720 and that seems even more efficient than the Inventors.
I also think the Victron Windows app is a bit limited as well!
Zero logging or history available all I see is a round circle with bars lit up dependent on load, nothing like in the pictures Victron provide online showing a bar graph over time at the bottom :( so I can't even capture how often the compressor does stall.
I will still try it against my 93L inventor later on, sods law says the big fridge will be fine unfortunately that's not the one I want to use in this particular van at this time!
Interesting to hear this. I think the power specs between the two fridges are the same but could have been a copy and paste job by the makers as the difference is not that important for most people.
I would think the 12/800 (700W) inverter would be ok? It must be really borderline if only happens in Eco Mode?
The logging on the Pheonix inverters is not very good even though the inverters themselves are excellent. The Inverters which have a VE.Bus connection are much better. This is what I logged with the Multiplus-II 12/800 running the bigger Inverter 93L fridge.
MP800-FridgeACvsOverload
by David, on Flickr
you can see the overload situation everytime the Compressor kicks on (so load >700W).
I have now tested this with effectively two identical fridges (both mine do have the same compressor) just in case on of them was faulty both compressors stall randomly on Eco mode using the Phoenix 12/500 Inverter, and both trigger high voltage alarms when stalled.
I am now in the difficult position of do I risk wasting another £100+ on the next model up the 12/800 only to find that's no good either! I think the answer to that is no it is not worth the risk.
I will (try to) return my Phoenix for a refund and buy a cheaper more powerful sine wave based inverter instead from elsewhere.
As an aside I have another inverter from one of my ex Ambulances a Sterling Power 1800 Quasi sine wave variant which I have also done some tests on before ruling it out as well.
The modified sine wave is not efficient, surprisingly so with inductive loads, the fridge draws approx 40 watts on the pure sine wave Phoenix but > 55watts on the Sterling power one!
however with a resistive load a 100W light bulb the wattage was less
Interesting stuff. I know as you go up the power within the Victron Range, the prices do tend to increase exponentially!
I wonder if your inverter is faulty? I think it is worth while getting it checked into.
For alternatives, maybe look at the Edecoa range available through Amazon? They are well made, very quiet in use and reasonably priced.
I had the 2500W EDEOCA PSW inverter. It did fail after about 10 month, but any product can fail so I was not that concerned for the brand as a whole (and I got a full refund for it on return as well) and in fact just bought another EDECOA a few days ago - 1500W Pure Sine Wave for £175 which I think is pretty good. Not cabled it up yet (for a customer install I am doing) but I am expecting good things from it :)
This is the 1000W unit version - https://amzn.to/2ETNCgi - but that is only £30 cheaper (think the 1500W for £175 seems better value?).
The inverters from this brand tend to be quite large physically as they use the casing with lots of vanes for primary cooling I think (but upside from the size is the quiet running (being quiet is very important for me personally - can't be doing with a fan running all the time).
I've got a very similar 3000w mod sine one in the transit (branded Spannungswandler)
Probably out of the same parent company by looks AND by the remote panel...
Can't complain at the cost (£170 ish) including remote and powered our microwave /kettle/toaster/slow cooker etc without issue.
"Spannungswandler" is just the German term used for an Inverter, so you will see quite a few with that label kicking around ;)
My bum is numb after spending a good few hours reading though it. I wish I had the funding and ability that you've clearly had. In the early days I had luck, but it turns out I was mislead by it.
Having ruined to much good food with a 3 way fridge I needed a better solution. Yes I know they don't work well whilst driving, but it had too.
The first lead into the unknown was around 10 years ago. I purchased a cheap under counter fridge "Husky" I had a small 200watt inverter. Previously used for running computer monitor from 12 volts. Heavy glass CRT versions. A friend donated a pile of ex UPS 6volt bricks. Luckily I found 2 good ones. Summer testing in closed bus, around 7 days run time for the fridge without disturbing it. For around a year all worked well, until one hot night we were rudely awoken by a very load bang and a smoke filled bus. Many inverters were purchased to start the fridge and we ended up with a 600 watt one that would just about start it. Run time was just over a day with the new inverter. Must be a duff fridge. So each time the old fridge was sold to by a new higher spec replacement. The fridge we have now is the hardest to start and most expensive, though reading your numbers were seeing about the same summer consumption. Hard start devices were tried and many other gimmicks. None worked. The journey into solar was only to keep the fridge running for longer without a generator or hookup. Fed up with poor functioning and low life inverters we installed a Victron 12/800 and though it coughs a little on some starts it's been doing well for two years. Charge controllers also bothered me as the displays of performance seemed fictional, and I now believe it was. From limited experience, they seem to be sunshine meters. Having changed over the again a Victron 30amp charge controller the improvements are shocking. This is a Bluetooth version so observed from my phone. Unless you observe the off load PV voltage it is no longer a sunshine meter. There are other ways to tell if it's sunny! If it's not loaded it appears to give poor results. When it's sunny and you've hammered your poor batteries you really get to see how well it works. I still feel that a 12 volt compressor fridge should be the best, though watch out as some appear to be 240volt ones with inverters built in. Again funding won't allow testing. If I had a good mate who was a refrigeration engineer I expect a 12 volt Danfoss compressor would be the way to go. That said, if I had a problem with my 240 volt fridge in Europe, it shouldn't be hard or expensive to replace it. Again well done in hard work putting this together. It should save a lot of people wasting money on the tall tales of salesmen.
Mark
I really dont understand Mark, I have used 3 way fridges for years and years too many for me to contemplate and have never had a destroyed food situation, can you explain how you have had this situation happen to you on what seems to be many occasions according to your post. Phil
P.s. I have also travelled on 12volt (13.6volt) for 48hrs in the past and still have had an acceptable low tempreture when parked up.
P.P.s
I don't decry the electrical advance that is being made and think that it must be the future, but I don't believe the horrors of 3 way fridges if installed and kept serviced correctly 😏
I know mate .....
Point I was trying to make was that there are a lot of units around that likely originate in a single factory BUT have different coloured casings/names etc etc (sometimes a good thing.... Sometimes a bad thing lol)
This is the one I have (12v 3000w)
View attachment 1386 View attachment 1386
Mark
As a fridge/aircon engineer I considered converting a, 240 fridge to 12v compressor....
Even with my skill set and qualifications I still ended up buying a 40l Waeco....
And ill be buying a waeco replacement for the 3 way in the motorhome ASAP.
It is the desire to not give salesmen lots of money to purchase goods which are no better than fairly common household items that led me to this pathway - and a way to NOT use a big budget I don't have.
80+L 12V compressor fridge ... £800+
80+L 3-way Fridge ... £1,000+
93L 240V Fridge... £170
Gas Hob .... £200+
My Electric Induction Hob ... £20
Hot Water Heater ... £140 Inc all plumbing. "Proper" Motorhome fridge ... Quite a few hundreds I believe?
It is easy to end up spending loads on stuff you are told you must have, so if my ramblings have saved some folk some cash that is good :)
P.P.s
This was many years ago with the fridge mounted in the front foot well of a Mercedes 608 LWB I'm sure the fridge was tired as well. Whilst in motion it required 12 volts and gas to keep it cool. The Merc had a wonderful air vent to cool it's back as well. Didn't want to work on uneven ground. Sometimes it would not work at all unless it was removed from the vehicle and rolled around a few times. I'm sure they are better now. That said we often hear stories of fridges not working well enough when it's silly hot.
Mark
I know mate .....
From the research I've done it does seem like a lot to change other than the compressor, that said I've seen reports of the simple route being taken and it working well, though technically wrong. I must admit as I get older, sometimes it's easier just to throw money at a problem.
Mark
Gas Hob .... £200+
I'm waving the flag, it does work. What's needed is this kind of guidance. Trying to do it cheaply with no valid help has cost me around £2000. But I'm more experienced now :(
Mark
